Wisdom!
marc1330
  Hill lover
Im after somebodys infinit wisdom. I have done a search but not found a definite answer. I have two mounts that I have already bought, the gearbox mount under the battery and the lower rubber block style gearbox mount. Its the little rubber block style mount that i am having difficulty in finding help for. I have adjusted the engine mount on top of the engine and its a little better but not much as im still getting a clunk when i lift off the throttle. Cheers
same here mate,iv replaced and adjusted all but mines still doing it,do you find your engine have a fair bit of movement coming on and off throttle?
Yep there is a fair bit of movement but when crawling in traffic when you lift off you get a nice clunk. Want to try and sort it before i take round the track.
