would these alloys fit my 07 plate clio?
  clio 5door sport rep
if a set of alloys is 4x100 but the centre bore and offset differs from the clio fitment will they fit or not or will i need something to make them fit thanks
If the centre bore on the wheels is smaller than that of the car they'll need bored out. If it's bigger you'll need spigot rings to fill in the gap. As for offset, you should be ok as long as you don't go any higher a number than standard or they'll end up hitting struts etc.
Yeap, they were right, I forgot the center bore diameter.
Stuiemc
  Audi RS3, Clio 172
Theyll fit mate centrebore is the same 60.1 Just make sure hes not using anysort of running gear and the wheels are fitted directly onto the hub.
