would this fit?
  Clio 1.4 16v Dynamique
its off a 172 wanting to know if it will fit on my 2003, 1.4 16V?
thanks
  PH2 172
U sure thats of a 172 the bore size looks really small compared to the 2.5mm bore size they have all you can do fella is try it
  Ph1
Not sure what the difference is in the Clio exhaust mounts but if their the same and it does fit up you'll probably find the pipe of the 172 will be a lot bigger than the one on your centre section. Cant see a 1.4 having the same bore exhaust as a 2.0 litre
