xenon problems
Car  VX220 lightning
my passenger side xenon has been out for about 3 weeks now, so i decided to buy one on ebay.. Used the car last night and it works!!!
Whats that all about?
Same problem as mine, my drivers side is constantley on and now and again it goes out, think its a falti connector m8t.
have u checked the relays under the passenger side foot arch my zenons went out after flickering for ages i thought noooooooo then looked under here tro see all the relays popping out lol
can you take a pic of where this is please mate?
I had a prob with my xenons before!!! was ok though once the dealer replaced the ones they knocked!!
its easy to find where u passenger sits and rests there feet under the glove to the left (basiclly where the left front wheel is there are 6 relays which can pop out and most common fault for these if u cant find this ill post a picture or send u one via tex :D
another problem is that renault in their wonders decided to leave a hole in the top of the starter pack which is screwed to the underside of the headlamp so water and moisture can creep in and corrode the main board. I removed mine and took the soldering iron to all the solder joins on the board. sealed the hole and i have no hassle at all. Saved £140 from renault for another!
