Yozzasport Custom Rear Springs
Car  Lionel Richie
who wants some then??? youll be able to lower the rear of your car upto -100mm on lowest setup
im having them built to fit H&R rear platforms (GAZ will be also available once i have measurements)
price is unknown as of yet because i need to know numbers!
the more i have made, the cheaper they are (im aiming to have 5 pairs made to start with)
post name below (and what suspension setup you have)
if they will fit my GAZ kit then put me down as a VERY interested (im assuming we are talking under or around a ton for the pair?)
i need the measurments of the GAZ platforms
the H&R lower platform is 60mm diameter (so minimum internal diameter of spring will be 61mm)
get me the measurements
ill have a set too!
H&R set up please.
ill keep em for when the coilovers come.
you still ok for fitting my set up Fred?...£50?
--chris
Ill try and pull my finger out of my ass and measure them on saturday. Whats the range -60 to -100mm? and any idea if ill need archwork at the minimum height on std rims and tyres ?
Quote: Originally posted by Fred2001Dynamic on 23 June 2005
Dansta (H&R)
Loony (GAZ)
Carbon Copy (H&R)
Alan C (H&R) please confirm
[Edited by Fred2001Dynamic on 23 June 2005 at 11:55pm]
<FONT style="BACKGROUND-COLOR: #407db6">the height range will be from -60mm to -100mm<FONT style="BACKGROUND-COLOR: #407db6">clearance will be fine
cool ta.
Quote: Originally posted by BenR on 23 June 2005
what poundage will you be running?
12inch bangin woofa!
not sure yet, i dont want them stupidly hard
ill await the prototype pair and give them a try
yeah elliot i do have FKs but everyone who has bought GAZ+H&R coilovers for their 172/182s want the rear lower
this is where i come into play!!
FK wont supply the rear springs on their own (same as your -80mm ones), so im having custom ones made up to "Fred" specifications
theyll lower the rear between -60mm to -100mm (adjustable)
currently the H&R setup only lowers the rear -50mm roughly, so the cars appear "nose heavy"
this is the look were going for, and will handle like a gokart
http://i4.photobucket.com/albums/y116/Fredmrsclio/IMG_1009.jpg
fred, this says springs, but ive got gaz coilovers which are not adjustable height, only damping. how can u make springs height adj? or are they going to be those coilover looking dampers for the rear? and not have springs?i dont understand :oops:
The springs fred is getting are the ones to fit with H&R and possibly GAZ coilover kits, neither of these run the coilover style rear damper but a conventional spring and strut but the rear spring sits onto a height adjustable platform that bolts into the rear trailing arms. Hope that makes sense clarkie.
ye it does mate cheers!
yeah Clarkie, these are for the height adjustable platforms
i can have some made up for your requirements, but itll be more expensive
would soooooo love a H&R set with the custom spring, is it possible to buy together or does this spring have to be purchased seperatly?
this is an "aftermarket" option im supplying to coilover owners
some people have shown interest in customrears for the FK coilovers also
im only missing the measurements for the GAZ setup, anyone in or near birmingham with GAZ coilovers so i can measure them up????
Fred im supposed to be on the piss up there with Lee "i love the p**n" M sometime soon. i can drop by for you to have a look on my way up. Either that or ill try to get the car on a ramp at work and measure it up.
fred, im usin fk rear shocks, not coilovers,but can i sit these custom springs on standard platforms? cheers
currently no ben, there isnt enough interest to make it viable TBH
this is only for the coilover boys
Currently
H&R = definate
GAZ = definate
FK = possible
Quote: Originally posted by David on 27 June 2005
that looks f**king awesome but cant the front wheels actually turn!!?
does look mint a bit like a saxos ride height when lowered. but id be concerned about scrubbing the arches when i went over a bump + getting over a speed bump with the front splitter etc.. also turning circle. how would a 60mm drop on coilovers cope with the above mentioned ?
im on my 3rd drivers side front wing and my 2nd passenger side one LOL
mine has full lock no problems (no arch liners)
