Right, now I have been using the Yozzasport Brake kit of Standard Brembo Discs and Performance Friction 97 pads and I thought I would let you know about how I got on as I have now had them changed.
I will start with a positive, if you want brakes with very good stopping power and thats all you are bothered about then these are for you!
Unfortunately, my experience starts to go down from here. I was unfortunate enough to go through a set of brakes (pads and discs) at Oulton Park last year but fortunate enough to have Yoz, Fred and Andy (GDi) on hand to help fit a new set of pads and discs for me and the only ones available were the Yozzasport setup so I really didn't have much choice but I was promised they were very good so went for it, and they are very good brakes!
I started to have problems with the pads, they were overheating just from driving on the motorway and because they had been fitted without the correct tools as it was onsite at Oulton without anyone prepared I thought it may be a fitting issue so I had them refitted.
I continued to have heat problems including quite loud noises at times on the motorway from the overheating and they were squealing like mad at low speeds, all things I could put up with really as the performance outweighed the negatives at this point.
The main problem I have with them are that they have ruined my wheels and my paint is not having a good time either down the side of the car. Basically the brake dust these produce is something out of this world, it is unbelievable. THe dust sticks to the wheels like nothing else and if it is left on there for more than 2 weeks is impossible to remove from the corners after trying everything on the market. Its now come to the point where my two front wheels have been damaged and will need refurbing due to me having to work so hard on them that i have gone through the laquer on the wheel. The backs are also suffering as the dust reaches them and on the way covers the side of the car in dust which means that every time i wash the car I have to polish the dust off as meerly washing it doesn't work!
I spend up to 4 hours each time i wash the wheels which is normally once a fortnight, can't leave it any longer than that!
So anyway, i've had enough now, I had some Renault pads fitted yesterday morning to make me a happier man again and they are fantastic, nearly as powerful as the PF but not as bity and inconsistent and I know the dust will be easy to get off and won't ruin the wheels anymore!
And it was lucky i did have them replaced as the pads on one side were only 1.5 mm thick after just 6 months and 8k miles so didn't last anywhere near as long as i thought they would! I thought they were going to be hard wearing and they didn't even do any trackdays, it was mostly motorway driving!
So in conclusion, they were amazing stopping power, loved the sparks in the dark but were not worth the upkeep and ruining a set of wheels and 4 hrs of my weekend solely on them. If this wouldn't bother you though, they are well worth the money!
