LB197
Hi, so ive just bought some mk1 clio wheels on ebay with a size of 195/50/15 and my current steelies are 165/65/14 can anyone lead me into the right direction on which spacers i'll need? thanks
thanks, if off-set is what i think it is, its the same 4x100, theyre the wheels of the 1.8 clio mk1,something abit different
mk 1 clio wheels are et37 odd, they will bolt straight on and sit in the arches much better than your standard rims, so basically everyones a winner
which did you go for as well, the older turbines or the bubble shaped vegas?
vegas have their place
4x100 is just the bolt pattern, the offset is how far the wheel will sit in or out of the arch, and is one of the major factors that will cause you fitting pains.
edit: According to http://www.wheelfitment.net/renault
You should be just fine as the offset is 35-38.
Just my normal bolts mate!
sorry, yes without the spacers standard bolts will be fine, or should be, obviously make sure you get them on with a good few turns before they pull up tight![]()
