172 cup ad08 size?
Car  172cup
Looking to buy a set of ad08s in the new year for my 172 cup. There are two sizes available 205/45/16 and 205/50/16 is there any difference? Is there a better size to fit the standard turini?
cheers
cheers
I'd go 205/45/16 as these are what I've got the 50 may be a little tall but ok on standard ride height I'm not sure, some minor mods dependant on how low you are, where have you found these they've become as rare as hens teeth, are these the new AD08R?
Regards Russ........
Ears Motorsport, but heard revolution Gateshead have some in stock. Standard apart from cooksport springs.
what difference, if any, does the r add?
I think these will be the new R rated tyre, for us who sprint / hill climb list 1A is a road tyre and the old AD08 has been dropped from Yokos list, unfortunately the new tyre AD08R moves them into the 1B list which is basically a cut slick or very soft compound, we can't use them, it's a real shame they've done this as finding a tyre with as good a compound and strong side wall will be hard.
Regards Russ......
hey man before you buy them from ears i just checked demon tweeks they are only 92 quid on there for ad08r's ! bargain
Regards Russ......
sprintcup
Russ, still have them below but these are 195/50/15 at £80 each
http://www.tyres-pneus-online.co.uk/car-tyres-YOKOHAMA/ADVAN,NEOVA,AD08/195,50,R15,82,V.html
I'm weighing them up myself:
AD08's vs RSR's and for £44 difference I am truly stumped.
AD08's I reckon Mick, don't have the common splitting across the tread fault like the RSR's, the edges won't wear low as quick, thanks to the better tread pattern design and their suppose to be better in the rain.
Question is, what's better AD08 or AD08R?
don't worry about the rsr split, it will wear off - that's what most experienced, I'm very pleased with the grip level they give
205/50 r 16 is too big, if the car's lowered wheel rubbing will occur
The cracking/splitting has never been a genuine concern to me as they seem to wear thru it but I currently have PE2's which have next to no side wall strength so roll pretty easily so this is what I'm trying to resolve with tyres for this year's playtime. I've seen the AD08 walls and they are deffo the strongest between them and the RSR's but they have a slightly lower tread depth to.
I've found the RSR's for £276, ADO8R for £315 and the AD08's for £320 so the saving/additional cost is negliagble vs what they both will do on circuit. One has a much harder compound than the other though which is where the AD08r comes in and what worries me as I like to buy one set that will last me all year and work in all weather (yeah, I don't want too much).
I'm personally swaying toward the AD08r right now... ordering in the new year as my first day isn't until Feb
Yeah I guess it's not a major issue with the splitting but still not nice to see.
I think I'm in going to go for the AD08R's aswell, hopefully they don't wear out too quick.
AD08R is the new name for them iirc? Not sure if you can get old AD08s now.
It's a completely new compound on them. Faster and last longer.
I run the older AD08s on my 300+ Megane at the moment but will be getting some Rs next
As per Jamie's post the AD08r is a new softer compound than the AD08 which is why the circuit boys cannot use them anymore as they're now classed as a 1B tyre.
I have been doing some more research today in between plans to modify my RS2 further and I am now set on AD08r rubber.
AD08s are awesome allround tyre. I will be selling my AD08Rs 205/45/R16 in Jan. I bought them new in August thinking they were AD08s (which they were advertised as) but fitted AD08R. They will have done around 500 - 600 miles sand never tracked or sprinted. I have a separate set for track ;)
I now have a set of AD08s on there way to me for the new sprint season hence why the AD08Rs will be up for sale once the AD08s are fitted.
I have no idea why Yoko decided to change it, the paddocks were filled with AD08 tyres for Standard and B class sprints. They're gonna see a big drop in sales in my opinion
I ran AD08R's on 15's at in a sprint at combe in October in mixed conditions. I found that running at a slightly higher pressure than I normally would made a good difference.
I found them really good esp when the track dried out.
Yeah, I think they possibly saw the RSR's as stealing the percentage of sales though so matched them on compound and dropped the price accordingly.
A real shame for you boys though, agreed
A while back Ktec were the cheapest for the older ones, might be worth checking them.
I did check their site but couldn't see them on their. I remember they were doing them at fcs earlier this year at £300 for four, which is good but that was without having to pay for delivery.
I know tyres-pnues.co.uk has stock of the AD08's in 15" but unsure of 16". Have used them before so don't be put off by them being in Germany because delivery is very swift.
I got up...
Cheers for the info - looks like a few of you guys couldn't wait!!
Think I ll be going for the ad08r, it will suit my needs better as only aiming for 3 trackdays this year.
Brakes are next on my wish list....pagids blues??
They are awesome pads but I personally use the DS3000's because not as pricey and bite just as well for the compromise of price.
Cool I ll give him a shout, going to order some of that brake fluid he stocks next month. Pads wise I ll see how thes standards hold up for cadwell first.
do the ds3000 squeal like the pagids?
They all squeal at low speeds once they've been truly hammered but mine never did prior to them catching fire (long story, not my fault)
Standard pads will not hold up on track and may spoil your day. Id invest in some pads if I were you.
Carbon Loraine RC6 are my weapon of choice as they bite from cold and bite harder than anything ive used but bloody noisy
After reading the post mentioning burning brakes, I remembered setting fire to my wheel/calliper/tyre at knockhill in a 182 - new pads is a good shout.
