Interior and number plate bright bulbs
Car  172 cup
Could people please give me some links for each bulbs as I have a tendency to buy ones that blow after a week!
im am after ultra bright white to freshen things up
thanks !
Jack 172 do you have one light for your interior light or does it have a map light too?
If it's just a single bulb, it's a 38mm festoon, and a pain in the arse to LED as it only works one way or the other unless you use two bulbs or a bridge rectifier.
If it's got a map light, then it's 2 w5w bulbs, same as your sidelights.
Number plate bulb is an R5W.
I'll put some links up later, I'm not on a computer at the moment.
@Jack 172 do you have one light for your interior light or does it have a map light too?
Yeah that will be great thanks, and I've just got the standard single bulb for interior
McGherkin do you know much about bulbs for the mk3? I've gone through no end of numberplate bulbs for mine - any you would recommend?
The second ones I linked that i use in my boot are excellent for that and haven't blown, can't see them being any different with the number plate and its the same type of bulb.
As promised ;)
Interior light, you'll need 2, and solder them together in opposite polarity using a wire from each end. (Or you could buy the courtesy light unit with a map light, and just use w5w bulbs without doing any soldering - I recommend you do this.)
http://www.ebay.co.uk/itm/like/3209...f11=ICEP3.0.0&ff12=67&ff13=80&ff14=101&ff19=0
Numberplate light.
http://www.ebay.co.uk/itm/Land-Rove...arts_Vehicles_CarParts_SM&hash=item51b5ea1881
Thanks mate I see someone selling a map light earlier for £4 I'll try and snap that up if he's still got it
Yup those were the ones.
Used the whole pack by the time I did the number plate, interior and door ones. Made a big difference
