Won't start
Hi all
my clio 1.2 won't start
turn the ignition and all the lights come on fine but when i turn the key further i get noting at all.
it doesnt do anything.
pretty sure its niot the batt as all electrics work fine and have had it hooked with the jump leads with no joys.
got a feeling its a immobliser problem.
any ideas anyone?
Jack
The immobiliser is not disabling then.
Try disconnecting the negative side of the battery for 5 minutes, then reconnect it and turn the key to ignition but see if the light goes out before fully starting.
I try that tomorrow but if that it isn't it what will it be
It could be the crank sensor. A lot of the time you can give it a clean and it will start. If not a replacement isn't too expensive.
