Help needed with airbag lights Essex area
Complete novice so please bear with me.
My son has had a small prang in his 52 plate authentique and the drivers side seat airbag has gone off,have removed the ecu and sent it off to get it reset,had replacement seat delivered from breakers in Scotland and the connectors under the seat are different.
Not being technically minded is there anybody out there that could lend a hand helping me get this sorted,thanks in advance
Cheers Kyle :)
Welcome to the forum mate
could take a picture of the two connectors ?
Hi Scrooge the breakers are calling me back as the seat they have sent has a height adjuster on it where as the one in my sons Clio doesn't.Think they have sent me the wrong one all together but here are the pics for you.
replacement seat connector (brown one)
http://sdrv.ms/1m2zeiB
Original seat connector (black one)
Connector on the loom (black one with red clip)
The replacement seat connector has two wires the original seat connector is three wires.
Ok, hopefully they get back and arrange to send you the correct replacement to save chopping into the wiring. You can chop the wiring about to get it to work or your other option is to fit resistors to trick the airbag ecu into think the airbag is connected.
Is there somebody on here who can help me with that,not very mechanically minded at all tbh.
