How much money have you got! If you go far enough you could go for a tubular spaceframe chassis with a fibreglass replica of the shell, that'd be pretty light.
What is the car being used for?
Track days only, trailer'd to and from.
It's getting boring reading the past threads with the same mongs commenting about losing weight/taking a dump on this thread.
If I lose 5kg in weight from the car it's permanent.
The car will be 5kg lighter whether I weigh 10 stone or 17 stone.
There are so many variables with peoples weight/fluids in the car etc, that its pathetic trying to be smart pointing out the obvious. But thanks for pointing out that if I go on a diet, wear lycra, no shoes, 1 litre of oil that will also contribute to stripping a track car.
To everyone that actually gave some input - thanks!
Why is making it as light as possible the be all and end all?
Racing, I can understand.
Trackdays, like f**k does 10kgs here or there make a difference.
So you're a fat b*****d, and stripping a car is easier than putting down the fork?
drop the fuel tank off and fit a light weight aluminium one in the boot if its only going to be for track use?
Ok great, i'll take a look, didn't think of these...
I don't know how much the original tank weighs, but I could see a 10-20lt tank being lighter than a 50lt tank. Might have to ask some of the other track day boys.
20lts of fuel is heavy in a can and must be 15 to 20kg estimate so i prefer that left in the pit not in my car until i need it.
I understand wanting to loose weight from the front, or you run the risk of having the rear so light that it could be like a pendulum if you got it wrong mid bend.
there is quite a bit of chunky foam in the front bumper, and the sound deadening on the bulkhead.
does/did the car have aircon, you could also remove the radiator element for it that's housed up under the scuttle panel within the fan box.
and to be honest, I don think people are being mongs but just having a bit of banter and a joke, which is all harmless.
maybe you just took it wrongly rather than just playing along with the light hearted humour it was all meant as... We are all men, simple things like farts, dumps and dirty jokes are always going to be humourous to us![]()
Bloody hell don't put a plastic screen in. The modern laminated screens offer quite a bit of penetration protection. You don't want to be killed by a stray wheel trim.
Seriously leave the windscreen alone FFS.
I may well do, I don't know enough about polycarb windscreens yet.
What is it you don't like about them? I know perspex breaks into dangerous shards, does polycarbonate also break in a dangerous way?
Kelv, you've done the headlights aswell which I debated, but not sure if this will cause problems for track days so I've put that on hold for the minute. Have you ever had problems on trackdays due to having no headlights?
I suppose the only further weight from the front now could only come from a lighter flywheel/pulleys etc? And starting to get very expensive!
What a monumental Knobend.
Roy- spot on.
Munson, you're wrong on most counts mate. Have a lot of experience in karts from 12 years old. I'm no racing driver but am perfectly competent on track. I'm sure with more tuition we can all find a few more tenths or 1/100's but it's not all about that.
At the moment i'm enjoying building the car up, and as it is my first track ONLY car there is a lot for me to learn. As its track only i'm taking the opportunity to go that extra mile.
You're firmly set against polycarb windscreens and exaggerate about a wheel trim flying through the windscreen, and you're effectively saying only Sebastian Vettel is worthy of a car with a polycarb windscreen? So all the people spending £1500+ on coilovers...do they need to be racing world champions? Carbon/ally bonnets? Lightweight alloys? Or just people who want to build a well rounded and capable track car? Who understand that all these small extra mods are going to work together to improve the car?
There are kilo's difference between a glass laminate screen and a polycarb screen. It's also weight high in the car and would complement polycarb side windows really well.
I know from karting how important weight and weight transfer is (weight transfer of your body but anyway). 5kg difference is completely different in a car, but regardless I appreciate light weight and thats why I like Clio's in the first place.
Could you provide an actual informed opinion (facts would be even better) to support why it is "utterly ridiculous" to suggest polycarb front screen? I would genuinely like to know...
Ah yes, more parts... Power steering removed and lightweight pulleys etc, but the pulleys are to ease the strain on the engine rather than making the car lighter.
my headlights cause no issues, but it depends on what trackdays you book, obviously I can't book on to the MSV sessions when it states 'For road cars only', and I do have headlights I can still fit and use if I have to.
ive got to ask tho, are you a trackday regular already?
do you get a lot of track time in and now just wanting to fine tune the art and looking at ways of being a bit quicker?
if not, then maybe you should get some more days under your belt and start to gain more experience before trying to take a car as close to a club racer as you can get.
and as like Munson I apologise if I'm wrong, and you are a hardened trackday veteran.
