Clio mk3 Headlight with projectors problem
Car  Clio 3 1.4 16v
Hi guys,
I need help.
I bought headlights for my clio with projectors and when i install them corner lights wont work.
They told me that i need to change wire instalation to get them to work.
Is there something else except wires that i need to bought... Like ECU, or some Sensors, Steering Wheel...
Before:
image upload
After:
free photo hosting
Think theres a sensor and something in the ECU/UHC? Someone else might have more info than me but remember reading a thread about it on here. Basic opinion was it isn't worth doing unless they're on the car from new.
There is a lighting control module (989) and some wiring that you will need first of all and you will need CLIP to see if the module is already in place. If so simply have it configured and it should work but honestly I don't think you'll have it:
Yes, it is required as it monitors the CAN ID from the SAS to monitor the steering angle which when the lights are ON then tells the UPC (1337) to switch on the NS/OF cornering lights accordingly.
Mick
Those little LED's look horrendous mate :(
As does the grill IMO.
Not upper or lower clio are mine :)
Here is mine http://www.cliosport.net/forum/showthread.php?692726-MK3-Clio-from-Sarajevo/page2
Mick
Really thanks for your answer :) Now i have a visionary picture what do i need to do for it :)
Mick
Sorry to revive an old thread. I’m looking to install this on my Clio 197 - what are the chances of the wiring already being in place?
If it’s not - is the extra harness required part of the engine loom, or is there a separate headlight loom? - I can’t work this out from eBay photos…!
I have purchased the 989 module and the headlights.
thank you.
