How big are these?
Car  Golf 7.5R & Clio 200
Selling some samples, was going to use the waxybox wax pots, are these actually 30ml?
For example, this is a 30ml sample Carbon I currently have
If they're smaller I'll have to find some other pots!
Think the waxybox sample pots are 15/20ml max
Will sned over the link to the place I use. Used my last pot for your spirit sample
Can you squeeze more of one substance in a 30ml space than another?
In water yes ml-g is the same, but most solvents weigh less than water ml for ml, for example, get a bottle of polish (say 500ml) and get a bottle of something waterbased like a detail spray the same size for instance.
So you see measuring the capacity by g is not accurate if the products going in are different.
But for the purpose of working out the size of those test pots yes, filling with water and weighing will work, say get get 50g of water in, then its a 50ml pot) but thats not to say you will get 50g of wax in it when you fill.
LOL!!
1ml-1g
So if you can fill the pot with 30grams of water then the pot in question has a 30ml capacity, no matter what wax you put in it.
