497adam ClioSport Club Member Car clio 172 phase 2 Feb 14, 2014 #1 As above, just wondered is this common? And is it normally the actual fan or is it the control?
497adam ClioSport Club Member Car clio 172 phase 2 Feb 14, 2014 #4 Is that in the main heater control ?
Budgie Car 330i. E30 Touring. Feb 14, 2014 #6 If it works on number 4 only, it's the resistor. If not, check fuse, check the motor is getting power etc. The usual checks.
497adam ClioSport Club Member Car clio 172 phase 2 Feb 14, 2014 #7 Doesn't work on any setting, will start with fuse
Fletcher ClioSport Club Member Car M2 Comp, 172 Feb 15, 2014 #10 497adam said: Doesn't work on any setting, will start with fuse Click to expand... Mine did the same thing. I changed the resistor, it now works fine again.
Fletcher ClioSport Club Member Car M2 Comp, 172 Feb 15, 2014 #12 497adam said: Where is the resistor ? Click to expand... Here's a guide.. http://www.cliosport.net/forum/show...iring-Climate-Control-Resistor-Pack-(Clio-II)
497adam ClioSport Club Member Car clio 172 phase 2 Feb 15, 2014 #13 Cheers, ordered a recon one off ebay
