Too wide? Rota content.
As a few of you know I've just gone and bought some Rota Grid's. Came to fit them the other morning and I think the rear ones stick out a little too far.
Here's a few quick photos -
What's everyone else's opinion on them? Is there anything I can do to get the back wheels in a bit more?
Im obviously going to wind the coilovers down and I'm planning to refurb them a gunmetal grey colour (open to suggestions though).
Dan
@ThomasBrentnall @Spinksy
  GTD, Lupo
I did think about that but if I got camber shims, wouldn't they stick out more as well?
They are very thin, I'm no expert but on my old Golf i was running 1.5 degrees of camber on the rear and it made the top part of the wheel sit much better under the arch. Having had a second look its going to take a fair bit of work to get them to sit better!!
I found this picture, and the car is running 2 degrees with hub spacers;
Hmm cheers for that, I'll have to look into it. Am I right in thinking 2 degrees is the maximum before you start to get really bad uneven tread?
Pauleds
  Merc Dueliner sport
I like them
I considered a set of rotas in 16" the other week as they have soft kumho tyres on them but I've stuck with 15"
Jekyll
I'd be looking at camber shims as it doesn't need spacers! I believe you can get them in -0.5 and -1.0 degree off camskill and ktec's website.
I like them though. What happened to the splitter?
  GTD, Lupo
When i had 1.5 degrees the wear was a little uneven! As for the shims I'm pretty sure you can just double them up. Best check before but they are quite simple to fit.
Dan@M.A.D. does some that are -2 degrees. I'm not even sure that they would be enough to tuck the wheels in though!
I had an accident with a kerb a while back :(
Ah right okay, I don't mind a little bit of wear but I want my tyres to last more than 100 miles :p hadn't thought about doubling them up.
MarcB
  182 Trophy & 197 F1
I love these alloy wheels.
If i could afford a set at the right time i would have them.
They look stunning !
  RB Clio 182
Very nice wheels mate, maybe you could change the rear stub axles to 172 ones as they are 5mm shorter.
RS1 all 172 models
RS2 all 182 models
  Clio 172 ph2
they look nice. defo need more lows and the front fit fine just rears arches need rolling. running any spacers?
  Mec 350 slk manual
Dan
the ph1 they were on before you picked them up on Friday had the rear arches rolled so the didn't stick out
  Clio 172 cup + 325ci
Not a fan of Rota wheels at all.I think the only way to make them fit would be camber and go the stance root but that defeats the purpose of your car.
What's the difference mate? I thought they were the same thing if I'm honest. How wide are those shims?
Thanks mate :) will be good when they're fitted properly!
RS1 all 172 models
RS2 all 182 models
Ooh that sounds like a good idea. How would I go about doing that?
Yeah I'll wind the coilovers down once they're fitted properly :) not got any spacers on. They're just really wide wheels! :p
Yeah but if you look on his progress thread, they seem to fit a lot better before he had the arches flared. I'll pm him.
As I said when you text me, I think these sit perfect! Colour is perfect too, just roll the rear arches and you'll be reeete!
Haha, still not sure on keeping them white :p
Yeah didn't expect everyone to like them, they're definitely a marmite wheel!
Just order a set off ebay or here mate and fit them/get them fitted, make sure you order the shorter ones.
http://www.ebay.co.uk/sch/i.html?_t...s&_nkw=clio+172+stub+axles&_sacat=0&_from=R40
Are the 172 and 172 cup ones the same mate?
  182, SQ7, Trafic
Those tyres and camber shims are just asking for a write off! Contact patch will be minimal!
I'll go for the 172 stub axels first, hopefully they'll make enough difference. After that I think camber shims will be the only option apart from rolling the arches.
@-Danman- I believe the MAD ones are actual spacers ranging from 5mm - 15mm wide from -0.5 camber to -3.0 where as the link I mentioned are just shims that add camber but don't space it out as they are only 1mm think (approximately)
Heres a pic of MAD spacers and the shims I had on mine. Imo you don't need spacers with camber as your wheels are wide enough.
10mm rear hub spacers: No camber Vs Camber by Dr-Jekyll, on Flickr
Ah right okay, I assumed that they were the same thing. Didn't realise you could get the camber separate to spacers. They will be a lot better! Thanks for your help :)
100% not decided. Get it lowered and we'll know. (or photoshopped)
Maybe someone could do me a favour ;) I'll have to fit them again and take some more photos.
I think they look perfect mate!
I like it! Love rotas!
Thanks guys, even the colour? Everyone seems to be saying keep them white lol!
cat171
Not for me, Jap wheels & tyre stretch don't work on a clio, unless it's going to be silly low.
