heaters blowing warm air
Bux
  Golf GTD
If your aircon doesn't work, it will be slightly warmish air that will come through.
  mk1 Octavia VRS
Not if it's freezing outside. It should blow through the outside air temperature (roughly).
It could be the common fault with the climate control - do a search for 'warm air' or 'hot air' and you should find it.
  ibiza fr tdi hybrid
It blows through warm air all the time ino my air con has no gas but even in the winter it was blowing through warm air fitted a new reo stat today as they packed up all together will be getting aircon regassed just gettin prepared for the summer lol
  Clio Sport 197 Cup
All sorted now was the cog on the motor in drivers foot well cost me a jubilee clip lol
You got any pictures of this? Mines blowing out hot air constantly too even when my setting is on cold! This could be my problem and an easy and cheap fix. Any help appreciated pal.
  Beaten up 182
Take the plate off in the drivers footwell with the two climate control motors, your problem will be obvious. A small jubilee clip and some araldite is all that is required.
  Clio Sport 197 Cup
Cheers guys. I found quite a lot of info on here about it including pictures.
Any body tried actually replacing the cog so it doesn't happen again?.
  ibiza fr tdi hybrid
Just use a jubilee clip mate or a zip tie mines still holding up fine cost me £1.29 to fix :) rather then £££££ to fix proply
