Water spot removal
cafcross
It decided to rain yesterday and then be sunny straight away, resulting in a lot of water spots on my car. I've given it a wash tonight with AF Lather and a quick coat of Werkstat Acryllic. I've managed to reduce them greatly, but they are still there, as seen in the pics below.
The ones on the glass came off with a bit of elbow grease and some AF Crystal, but the ones on the paintwork don't want to budge. I reckon with some elbow grease they will come off, but I don't want to marr the paintwork. Is there any alternative to claying and/or polishing to remove them? As I don't want to remove the Collonite that I applied only a week ago after polishing. Or is this the only solution?
Looks good. Have you used it before Dave?
The closest thing to a QD I have atm is Autosmart Reglaze, but this did not seem to make much of a difference.
If the water spots are due to living in a hard water area then they will be limescale and therefore incredibly abrasive.
A weak acid like fresh lemon juice should loosen it so that it can be dabbed rather than rubbed to remove the mark without causing any scratches.
At least that's what Aggie and Kim would say.
I'm in a pretty water area and typically a good QD removes most marks after poor rinsing and drying during sunny periods.
Not used spotless yet, but more than likely get some with my next order now I have a black car
I haven't read anything about the new CarPro product yet, but I'd imagine it's ideal.
If not, Britemax #6 is very good for water spots.
Carpro spotless! It's an absolute life saver. I had to carry out a full detail in direct sun (23 degrees) and the car was ten times worse. Spotless did a fab job & is now always in my boot!
Sold!
Do you need to apply with an applicator as per the instructions, or does it work by spraying on and then buffing with a microfibre?
I 're wash a panel at a time. Apply via mitt/sponge. U can feel it cutting into the spots. Then rinse & dry! Amazing product imo
Wow. Thanks Dave and Dawn for the recommendation.
CarPro Spotless worked a treat. The bonnet needed 2 applications and some spots needed a firmer rub, but my paintwork is now water spot free!
I've found using 2 people with megs towels works best. Literally as soon as its rinsed, crack on at light speed before it gets a chance to dry
Grrrr. It rained today and the sun came out straight away afterwards whilst at work, and all my hard work last night is ruined. Water spots everywhere again!
at least it won't be hard water marks
My car has been covered in dust, and after a quick shower just now the black paint is looking aweful but it can stay like that till the weekend.
