Drivers door noise
Car  Clio 172 Flamer
Wondered if anybody knew anything about a common problem in the clio's where you close the drivers door and it gets to a point and makes the same crack/creak noise everytime.
Tried doing it slowly and I know the point it does it, the silver bar where the hinge mechanism works seems to be the issue.
Tried WD40 to see if that helps but it is not a squeak so didn't have any effect.
Any pointers would be appreciated.
So it doesn't sound like a golf??? Probably cos it's French.. As above check or change.
Not aiming to make it sound like a golf... wondered if it was a common thing and easy to fix, not overly bothered.
If i wanted it to sound like a golf, I would have kept mine.
My parents mk3 Megane Coupe has this trouble at the moment, car is going for a service with Renault on Wednesday and we've been quoted around£55 for the check door strap!
