Unable to select 1st or 2nd
.Joe
Hi there, in a bit of a pickle at the moment, on my way to work today i had a bit of a clunk into third and after that i was unable to get it into 1st or 2nd and barely into reverse, i have a PMS linkage fitted currently
does anyone know what could have happened?
Many thanks
joe
.Joe
What is the size/ Renault part number for the circlip for the gearbox end of the gear linkage?
Needed urgently
Many thanks
Joe
.Joe
2 sizes to the circlip
Item 3 / 4
It's the circlip that sits on the end of the gear linkage I believe, somehow managed to work its way out, I have a ridiculous amount of slack in 3rd gear, so if a oil change doesn't sort it then it'll have to be off for a rebuild
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
wait, if your diff circlip had popped, you wouldnt have any drive at all. picture of ' said location ' needed before everyone jumps in and says allsorts.
