Excel Help Please
Car  1.8 Civic EX
I'm sure the answer will be "use a pivot table" but the simple fact of the matter is, I do not understand them, every time I've tried it it hasn't worked. So if this is the answer any help on creating one would be appreciated. I use Excel 2010.
What I need to do:
Two columns full of numbers, A & B. Some numbers in A are the same and B are all different. I need to sum B if A are the same. That make sense?
Below for example, I need something that says Where A is the same sum B.
A B
1 1
1 16
1 17
1 2
2 3
2 7
2 8
3 2
4 1
4 2
4 3
So the result would be 1 = 36, 2 = 18 and so on.
The problem is my column A is 42k rows deep.
Help? :S
Scrap that! just worked it out using the "consolidate" function, never even knew that button existed till now!
I know you don't need any help now, but I've read that about 8 times now, and I'm still none the wiser as to what you were trying to achieve, lol.
Where a = x, add up corresponding b
I didn't read the post just looked at the data and the 'answer' lol
I know you've got the answer but there's another way... is it using a SUMIF?
I know @The Boosh is a bit of an Excel guru, but he'll probably come back with a VBA script ;)
I'd have gone with this, a SUMIF, or as your data was totally suited to it, I'd have subtotalled the sh*t out of it.
