a good track brake set up?
Car  172 ph1
We are coming to the stage of upgrading the brakes on the ph1 and just wondering what disc and pad set up people use which works?
Dan
Another subject that has been well documented on here.
HC discs, and then the list of pads will go on forever.
Ask George.
@G 172
Sounds good I'll look into these hc's it's just we are fitting a set of cams and itbs so need the stopping power
Brembo HC front discs with DS2500 pads all round is all you need. Been running this set up for several years now without any fade. Also braided lines and DOT5.1 fluid. Job done
Ask George.
@G 172
Ta lads, as been said Brembo HC discs and then some good quality track focused pads from one of the bigger names. Everyone will have their personal preferences, I like the Ferodo Racing range
If you want any help/advice or prices/options drop me a PM Finny
cheers
