Dual Screen Help
Andy_con
Car  clio 182
just *borrowed* a couple of old HP desktops from work and I want to run dual screen on one.
sorry to sound stupid but whats needed to run dual screen?
ok, think the current screen is ran off the mother board
You just need a video card in the PCI-E slot (long black slot) to attach the second monitor to (or alternatively a video card with two outputs on it and then don't use the motherboard output)
ok thanks, again without sounding stupid what should I be searching ebay for?
its only to run my cnc machine so doesn't need to be anything fancy. mach3 on one screen autocad on the other
If it's a small form factor PC, you'll need a smaller card than standard. Worth checking.
As long as you are not playing games, then pretty much any card will do the job.
If you have 2 different outputs (say, a VGA and a DVI / HDMI) already, you dont NEED a new card at all, but you will put more load on your exsting kit
As Gareth has linked, you need something with multiple outputs on the back, the first card is no good.
Would also be worth checking if you are running VGA or DVI as the connection, if DVI you could get one with 2x DVI instead of having to convert it.
If its the same as the HP desktops at work, you can use a displayport to VGA adapter along with the onboard VGA for dual screen goodness. Correct me if im wrong but it appears to be the same as HP DC7900 SFF, if so it will have a DP port. can you take a snap of the connection on the back ?
like I say I want autocad on one screen mach3 on the other, its not for gaming or anything
hope these photos help?
I just want another blue connected to plug the second screen into
OK.
If you have a DVI-port on one of your monitors, use the big white DVI socket, that will output to one monitor.
The VGA (blue port) can then service the other monitor.
No need for new graphics cards etc. once you have 2 monitors connected the PC should recognise them automatically, then you can configure them through right-click options on your desktop
ah, you may struggle there.
The DVI output on your PC doesn't appear to support DVI-VGA connections.. else there'd be 4 little pin-holes surrounding the long hole on the DVI socket. (I learnt this the hard way).
You need a DVI-D lead to go from PC to monitor.
ah this will be why the second screen isn't working, thanks for the offer but am going to go computer shop shortly to grab a proper cable
yeah, I went through several connectors and leads before I actually asked google and found what I needed, instead of what I thought I needed
how did manage to fail?
get up PC world, you know what connectors you need now :)
Hell, you can probably get one from tesco, or wilkos!
cos they didn't have the right one
maplins want £25 for the bloody cable!! ebay they are like a fiver
lol maplins is £5 fuel plus £25 for cable
found a chap on ebay £5 cable £5 cable
sadly I still have a full time day job :(
bits and bobs coming in but not enough to even consider giving up or going part time yet
when I do get jobs the money helps pay the bills so cant be that bad
