autofinesse triple and then power seal or tough coat...
So I am looking at getting a new sealant for the daily and was also thinking I might as well get some triple at the same time
is there any reason why you should not use triple and then power seal on top? Or would tough coat be better? Would the filers in triple cause a problem?
Power seal is a very long lasting sealant that needs to be worked well for it to bond. Ideally with a DA. Whereas toughcoat is simply spray on, buff around and wipe off. Power seal will bond over tripple but performs better on a bare paint base
i used tripple, toughcoat then spirit today first use of toughcoat and cant believe i never used it sooner SOOOO easy to apply and remove results are stunning a! i am impressed :)
Toughcoat over Tripple is a brilliant combo, very durable and gives a lovely wet finish especially on lighter coloured paints.
I am a big fan of C2V3 but you can't go wrong with either tbh.
