parts diagram for rear axle, brakes etc
Car  Clio 172 cup
Afternoon.
I started dismantling the rear beam of my 172 cup this afternoon to refurb it. some parts are very corroded and are maybe beyond repair particularly around the brake compensator valve area, but im not sure what these bits that I may need are called. so does anyone have any exploded diagrams of the rear braking components and rear axle assembly.
im I right in thinking that the ridged brake lines cannot be purchased as an completed ready to install item? they need to be made/bent/cut to suit like you would say when doing copper water fittings in the home?
finally the brake compensator valve failed its mot due to it being excessively corroded seized is the below item from europarts th correct item to replace it with?
http://www.eurocarparts.com/ecp/c/R...173693bc3c1247b231c8dabd6ca467e9ec9c1d&000417
Thanks for that, only part I can see myself needing right now is part numbers 4 & 17 of the braking diagram
is there an online parts diagram system for renaults? With peugeot and citroen theres a system called service box
