dann2707
		I've noticed in the past few weeks it has been getting way way harder to get into first and reverse, having to really wiggle it s**t loads!
I had a look under the gaitor today and it's apparent that the plastic bit that stops you from going into reverse instead of first seems to be blocking the way for when I want to go into first! I hope this makes sense.
I cannot physically select first gear now as shown in this picture despite it being at the furthest bit of it's travel left:
		 IMG_0330 by dann2707, on Flickr
However this is in first gear absolutely perfect but note how i've had to lift up the reverse bit!
		 IMG_0331 by dann2707, on Flickr
		 IMG_0332 by dann2707, on Flickr
Am I right in saying I need to undo that 13mm bolt on the gear linkage and adjust it to the right a bit so that it will go into first without it catching on that plastic bit?
If so how do I do it again please? Like what gear do I leave it in?
Cheers!! Hope this made sense.
