@imprezaworks Do you have a link to these online?Ah okay mate, plans sound good. Tbh i find the ecp pagid pads at £15 ish brilliant, and have used them on track too. If you feel the need to experiment, honestly try those.
That's exactly what I was trying to avoid.....Just ring the local ecp, give them your reg and ask for the pagid pads mate
The very same, thanks for checking fella! Ordered, now just to wait and see what shows upPart number
101745248
Fairly easy job to connect some donkey dick up to the fog surround and direct it at the brakes if you decided to.fog light removed etc helps massivly imo. Free to do aswell :smile:
Few pics of My brake cooling setup when I was fitting it (on a mk1 )
Ideally you want to force air up through the centre of the disc to cool it evenly the only problem with this is as I've found is a lot of clio discs are vented from the front instead of the rear and it really doesn't work as well
Like this
Instead of like this
When I get chance in going to make some better ducts that fit to the hub something like this
Here are my efforts - nothing special but i hope effective.
No worries. I like them and for £15 they are good value imo
Im such a t**t. It never occured ti me that if I had ordered regular ducting I could just force it into place between the carbon cannister and the horns. LoL
