exhaust is knocking after fitting poly bush dog mount
I had this. Its hitting the sub frame. There's an adjustment on the front of the dog bone. The extending arm that bolts to the bottom of the engine/transmission is there to effectively tilt the engine slightly forward or back a few millimeters. Its black and bolts to the front of the dog bone. I think its either a 15 or 17mm spanner needed. I think if you pull it in towards the back of car it should lift the manifold clear enough to stop it knocking. If you have a feel round you feel how close it is. Hope this helps.
This connecting bar jamesycc?
