Cookie
Nothing for you if you've not done the sleeper simulant quest lineWhat strike is this and whats the rewards?
I'll be down for doing it later on after work kida 5:30 pm?
Do tell...The saber strike is probably my favourite and fastest. Glitching underneath the warsaat makes the beginning much easier.
I can't really explain it without showing you the particular hill you need to be on, but there should be YouTube videos. You stand next to a hill facing forward, as you are summoning the sparrow you turn towards the hill and down at the ground, as soon as the sparrow appears you boost into the bottom of the hill and you go through the ground, walk under the warsaat and it thinks you are stood next to it. Once that's complete, run towards the ocean to drop down and die, then respawn back up on top.Do tell...
The touch of Malice is the result of the Raid.How do you get new quests? I've got f**k all apart from one that requires the raid to be run.
There was a new mission showing on earth the other day for an exotic Fusion rifle. Not sure if it's still there now though.
Not many new ones popping up now buddy, which is a little lame really. No doubt there will be another £400 expansion soon though, to open up another 15 quests.All I've got is a quest to slay the warpriest, golgoroth & oryx. And the one which is obtain the blade of famine, shroud of Ir anuk & the ravenous heart. So both of those require me to run the raid.
Just would like to have some other quests as now I've done all the ones i had I'm wanting more.
Remind me, are you Xbox or PS4?
I sure am.PS4 fella. Your Xbox aren't you?
JP and I struggled through the Nightfall too. My God it's a pain in the arse. I got 20 Strange Coins![]()
I have to get my Hunter & Titan through...NEVER AGAIN
Yeah I still need to do it, will probably be online laterI have to get my Hunter & Titan through...
I hope your TV is bubble-wrapped.Yeah I still need to do it, will probably be online later
I rage less on nightfalls as there's not much jumpingI hope your TV is bubble-wrapped.
That's what you think. Jumping about is pretty much all you'll be doing in this NFI rage less on nightfalls as there's not much jumping
Up and down, fine. To get to a ledge, noooooooooopeThat's what you think. Jumping about is pretty much all you'll be doing in this NF
Yeah it was a bit on the laggy side for me earlier in the afternoon. Morning was fine though.
Just randomly checked out your GT and realised it was you I was doing the raid with, I thought it was just some randomer that messaged me from the Tower
Edit: Just checked some more... Apparently it was mostly if not all Cs Members...![]()
Haha! Yep, it was a mini CS meet...
At least my GT is obviousJust randomly checked out your GT and realised it was you I was doing the raid with, I thought it was just some randomer that messaged me from the Tower
At least my GT is obvious :wink:
That and if someone is calling ships or ledges c***s, it's me
