Climate Control Fault
  Silver 182 FF
Hi, I've got an 04 Clio 182 FF and have an interesting fault with my climate control. I can set it to max temp and get hot air out of it, set it to min temp and get cold air out of it but not on the same journey. Whatever the temp is set to when I start the ignition is what it stays at.
Puzzled what to start to test/replace, etc... Any help appreciated.
  Silver 182 FF
Well bought a brand new Renault Clio 182 heater resisto, fitted it and still have the same problem, can get both hot or cold air out of unit but not one after the other. Have to turn ignition off :weary::angry:
  Clio 172 Merc ML55
Checked the motors on the side of heater unit? I've seen some threads that mention the motors/spindles wear over time resulting in problems adjusting heat settings, would be worth a check to see
  Clio 182 sport
Seeing as youve checked your resistor..this is definitely your next port of call bro
  Silver 182 FF
Thanks for the help, will check this out. My new steering wheel will be here next week and I've got washers to fit under seat runners. Perfect time to mess around in drivers foot well when there's nothing in the car to get in my way :wink:
  Clio 182 sport
top stuff did my wheel a few weeks ago pretty straight forward just make sure the steering sensor is on yellow(not moved) before you hook the new wheel on and battery back up..this was the one thing no guide mentioned and caused me all kinds of headaches :)
GrahamS
if you can get this plugged into CLIP it will be very easy to diagnose. Usually a problem with one of the temperature sensors reading incorrectly.
  Silver 182 FF
top stuff did my wheel a few weeks ago pretty straight forward just make sure the steering sensor is on yellow(not moved) before you hook the new wheel on and battery back up..this was the one thing no guide mentioned and caused me all kinds of headaches :smile:
Thanks for the tip. How do I know if I've moved the steering wheel sensor?
Is it only Renault that have access to CLIP?
GrahamS
well it is, those ebay units are cloned units. you have to then install the software on your laptop.
pretty much though yeah. Mine has paid for its self multiple times over.
  Clio 182 sport
you will see the steering sensors behind the wheel bro its got a little window just make sure its on yellow (it turns to change colour)
  Clio 182
Did you get anywhere with this? I have a similar prob, can get cold on min but on 16 degrees and above it tries to cook me. Fan works fine. Have done stepper motor / baffle fix and replaced interior temp sensor. It is as if the temp on climate control is mis calibrated....
