What gearbox.............
Pauleds
Car  Merc Dueliner sport
What gearbox is in a1998 megane cabriolet with the 2.0 16v F7R engine? What others fit?
Hole in the gearbox right above the diff so need another one.
There will be a code stamped into the casing of the gearbox, find that and then match it up with a new one to make sure it's the same, once you've found the code it'll be easier to find another
Cabriolet F7R
before 01.1998 - JC5025 / JC5053
after 01.1999 - JC5091 / JC5108
I'll check if you gave me date and month of production car. YY/MM
September 1998 mine is.
I've been told a 172 or 182 box will fit, is that true?
I'm not bothered about ratios it's only for the Mrs to bomb back and to in
Found this but i'm not sure for 100%
The same boxes
JC5025 / JC5053 / JC5062 / JC5091 / JC5S23 / JC5S57
