Centre clock bezel
Once you've gone as far as the guide shows, remove the 2 screws holding the clock in, then flip over and disconnect the 2x plugs at the back and the clock is removed. There is about 7/8 small torx bolts (t15 I think) at the back of the clock. Undo those and the back is removed. I used a small screwdriver to prize the surround off and just glued it in when I refitted it after painting it.
Hope that helps.
