Front suspension Creaking noise (bilsteins, solid top mounts ???)
Car  Clio 172, BMW 120i
At the beginning of the month fitted my coilovers, solid top mounts and a few other bits
Since then there had been a creaking noise (sounds like a creaking floor board) when going over bumps
The bits I had fitted had once been on my 172 for a few months then when I got my 182 I swapped it all over
The bits I swapped were
Pms Solid top mounts and strut brace
Bilstein coilovers
New track rod ends
1 month old ball joints
Wish bones
Powerflex wishbone bushes
Powerflex outer arb bushes
Today I've had the wishbones off and re greased all the bushes but it still makes the noise
Does anybody have any ideas what it may be or experienced it before with Bilsteins, solid top mounts, etc
Thanks Robbie
You say that, but I had nylon rack mount bushings and at parking speeds mine was still creaky. I had the same spec as OP too, everything refreshed.
Have had loads that have creaked at slow speed and has been rack mounts, not the bushes.
The spherical bearings have zero protection from water ingress from the wheel arch.
Remove & check for free movement.
Thanks I'll give that a check
Did you do anything to prevent it on the ones you have experienced?
I've heard they can get a lot of road dirt on them and fail early, i plan to make a cover somehow with mine to prevent this
