Oh cool. How did you mount the tunnel side harness? were you able to find a hole for the harness eye? From looking today I could see that the current safety belt buckle is fixed to the seat.Yeah i have a pair of Cobra Suzuka's with Schroth Harness', 6 Point on the drivers side and a 4 point for the Pax
It already has KW Clubsports fitted with adjustable top mounts so not planning on doing too much there. I've ordered Dunlop DZ03G tyres too which are supposed to be good. I had planned on fitting a LSD diff to it but it was going to cause a big delay on getting it so instead I'm planning on fitting one over xmas.What are you going for to improve the handling.
Will you be looking to copy the cup racers?
Love it mate! Keep it up
Yeah I know what you mean. I had 182's before hand but really like the 197.I've got to buy one of these asap.
You must have the special brembo pins. Think the guy who does them is on 197.net might be Mr pink? I'm not sure don't quote me haha. I'm sure he'll sort you out. The brembos normally have pins that need thumping out and are a right pain haha.Some photos from the weekend. Tyre fitting.
New tyres fitted and new wheel stud conversion. I also pressure washed under all arches as it was pretty dirty underneath.
Nice and clean! I ended up removing the rear carbon diffuser to see if I could fit the tow strap some how and in the process broke one of the mounting studs. So removed the two heavy mounting brackets and re welded a new stud then took the hole saw to the brackets to lighten them.
Also gave the front pads a quick check over to find that it has Ferodo DS3000 pads fitted which have had a fair bit of use by the looks so will look to change them for CL RC6 pads after Abingdon. In the process of removing the pads one of the R clips on the brembo pins broke. Does anyone know if you can buy those separate?
