Which cams?
I'm looking at getting an engine rebuild (as you may know by now) and a set of upgraded, aftermarket cams put in there.
I want some that are suitable for daily use but will give a little more power when going for it. I also want a set that won't break the bank!
I don't really know much about cams/engine internals so this is why I need CS' help 😌
Also, I'll be getting the engine rebuild down south in hope to be able to drive it back. Will it be alright driving a few hundred motorway miles before getting it mapped for the cams, or should I be getting it properly mapped before driving it at all? I'm looking at a custom map but at EFI parts which are here, up north.
Cheers in advance x
I've already been in talks with EFI about getting it done but nothing has been set in stone just yet. Engine Dynamics did mention they could get the mapping done but I didn't know if they did it in-house or not. Are they renowned for good mapping?
BashRacing
K Tec 438 cams are very very good,
Keep the revs below 3500 and you will be fine driving back to efi,
  Clio 182
I have just fitted 438 cams to my Clio with uprated valve springs and a sm inlet. They are awesome especially on idle. Not as lumpy as some cams. But you still know that they aren't standard. I can't give my engine any hard revs at the minute due to me still running the piston rings in.
Who is doing the rebuild.
I'm thinking Engine Dynamics, but I still need to source a replacement engine for them to rebuild and also get the car down to them. Trying to piece everything together and get as much info as possible before going ahead!
realnumber 1
I've been happy with my 197 cams (on group N timing iirc) and efi map. Drove mine for about a month before the map. Was okay apart from it'd stall at the lights quite a bit.
Cheap and the car goes noticeably better too:cool:.
