Were all 172sfitted with front fogs?
Car  monaco 172
I noticed tonight that my front foglights don't come on with the rear foglights and on the left stalk there is only 1 click which turns on the rears.
I remember on my 182 1 click did the fronts and another click put the rears on.
Am I missing something? Is there a different switch for them on a 172?
If not then maybe they were fitted just for looks, but I thought all 172 came with them as standard.
It sounds like you have had an aftermarket steering wheel on at some point and some body has removed the front fogs or done a pikey move on the wrong type of horn stalk - you can get 2001 stalk with horn and both fog switches.
And yes a piece of p1ss to fit.
Put an offer in on this and possibly £8 delivered mate.
Is the horn working when you push the centre of the wheel? If it isn't I bet it isn't wired up OR they have botched the wiring underneath the steering wheel airbag and then you will need a new squib which contains the airbag, cruise controls and horn wiring.
Nah it only works from the button on the end of the stalk.
If I go for a stalk with both fogs and horn button should it just be plug and play with the existing wiring?
I'm not too fussed about where the horn is if it's gooing to mean messing with wiring
Possibly disconnected (but why?), sounds like somebody may have melted the horn wires (very common).
Sounds like you will need new (2nd hand) squib and a stalk to get it working again.
BUT just check that wiring behind the steering wheel airbag first mate - hopefully unplugged as you say you have a refurbed steering wheel on so somebody has been removing stuff.
Right ok thank. I'll have a look tomorrow and put some pics of the wiring on and hopefully somebody can advise me on which stalk will be the best option.
Yep do that buddy.
Disconnect battery for 15mins before removing the airbag. 2 pins at 3 o click and 6 o click on the back of the steering wheel - flat screwdriver will push the metal pins across an release.
Yep do that buddy.
Thanks matey. Will report back tomorrow
