chris blue
								172 Ph1  2001
				Realise there are lots threads on this, just uploading my experience with this over last few days.
Clio wouldn start first thing in morning during the week, but there was a heavy frost.
Came home that night to try fix, and accelerator pedal lying on the carpet. Realised that the cable had snapped so got a Eurocarparts one for about £16, and luckily there was an RAC bloke in their helping someone buy a battery for £90.... (Must be agony). Anyway, he told me all the cables break right by the accelerator fixing, as mine had. The ends of the cable i was purchasing didnt look the same, and he said dont bother buying one from Renault (£40) as they are the same
The lug that goes into the throttle body cog, is a lug you put on yourself at the end of the cable, and tighten a screw, unlike the original.
Right,(i thought) just replace the steel wire in the cable sheathing, and leave original sheathing in place. Sorted that tickety boo, then had to bump start the car down the hill cos it wouldnt fire. Accelerator cable fixing snapped at the pedal end. It seemed tight, and a bit high.
So- sod this. Got "at home" on RAC so called them.
Cutting a long story short, it seems all aftermarket cable sheathings for the accelerator are different in length, meaning less steel wire to adjust, making the accelerator pedal high and tight. Thats why it snapped, so he said.
He couldnt sort it other than get the accelerator to work (again) but very tight and high (Again)
He told me that rsather than replace the whole cable with sheath, a right bugger to do, cut back the outer sheathing by about 4cms to give more play, or book it into Renault, which, when I enquired they wanted £100. Sod that
So- spent a while cutting back the outer sheathing, more play in the cable, and hey presto, a bit more slack and pedal back to a more sensible position. Not sure its sorted, but seems OK. Its just shorter so a bit less play in the engine bay.
Sting in the tail............... he told me starter motor was OK, Alternator was OK, but battery is fooked. He wanted £90 to supply and fit a BOSCH, said no, gotta collect one at Eurocarparts for £45, and fit myself. Exactly same battery. Think I can just about handle that
Moral of story- dont trust aftermarket parts, and fit them in total rather than taking shortcuts. Or expect some pain.
Watching the footie now, after that for a Saturday morning
