Clio 182
				I know this subject has been mentioned before on the forums but I am still yet to find the solution as to why i have the three lights up... I bought my 182 about 3 months ago and ever since iv been trying to resolve this issue!
The guy i bought the car from said it was an ABS ring on the drive shaft. so first i got the car home checked them and couldn't see any cracks or issues with the ABS rings so that was out the window. I also tried swapped the driver shafts for some spare ones i had.
I then put the car on a diagnostics at a garage twice which i was told the steering angle sensor was not responding by two garages, so i swapped out the squib with one i had which came from my last 182 which was working fine. The lights turned off but then eventually came back on after a while.
I have tried the brake switch and adjusted that so the brake light come on as soon as the brake pedal is pressed and tried a setting that made the lights come on a little later and this has still not resolved the issue.
I have just read online that wheel bearings can be a cause for no ABS or ESP? is this right or do the ABS sensors not regulate wheel bearings on the clio mk2?
I am at my wits end with this now and my only resort is to give in and take it renault dealership which i know will have my pants down over this.
Does anyone have any other ideas?
