Clio 172
So.. oil change done. Only had my toolkit since xmas, and I've already broken a handbrake cable and an injector!
How's the handbrake cable broken?
SH1TM3CHAN1CAnyone have an ECP code? JANSALE doesnt work on it 😧
It sounds like you've just figured out how to w**k off Eric your new sex doll.Done step 1, I was trying to pull the tube off, I didn't realise the plastic bit was like a release.
Oh and don't forget to disconnect each electrical connector on the injectors or you'll probably snap the rest off too.
So removed the feed, undone 2x10m bolts. How do I undo each electrical connector bit mate?
lol, kick the kid whilst he is down.Fair play for having a go, but you seem utterly clueless if you can't unplug a connector, lol
Next step is to remove the rail. Pull firmly as you angle the rail down and the injectors will come away from the inlet. The o-rings will be tight and horrible to get in and out..
I tried changing the pads on the Vee once. Started at 9am, at 7pm in a blind panic as the thing was still on axle stands and it was going dark I rang my mate to come and finish the job off for me. I hadn't even done one corner as he informed me I was in the process of dismantling the whole front suspension.I am utterly clueless, happily admit it!
Once you've removed the rail, be sure to plug the holes with tissue overnight too.. UNlikely anything would get in there, but better safe than sorry.
Also worth mentioning to get the injector o-rings back into the inlet when re-assembling is a fiddly b*****d. Need some kind of lube (wahey) to make it slip in better.
Use something rubber safe if you have it. If not, a bit of petrol/spit on it will do the job alright (pikey method)
Pulling and pulling, not much is happening. Just movement up and down. Should they just pop out?
@Davyy unless your in a hurry I got an injector 3weeks ago off the ebay for £29.99 posted. Genuine or magnetti marelli one too. Ecp are expensive and gsf is only worth it with a discount code on the weekend, they work out about £35 ish. Get a strap tool for the filter. I wouldn't go at it with a hammer and screwdriver as you don't sound like the most confident spanner monkey:smiley:
You've got the whole forum helping you here 😂
