Help please.. have I broken my car?
leeds2592
  Bean 182 + E70 X5
Looking forward to part two and fairplay for doing it yourself. I love doing stuff myself, makes you feel loads better than just dropping it off at a garage and throwing money away.
Stay Puft
  Clio 172
Fitted the new injector into the rail easily enough.. but cant get them to plug back into the engine. Put a bit of oil on the o rings but they just wone pop!
Gus
  182Turbo,DCi90
Dont worry about the up down movement, look at each injector to see if the o ring is pushed in to the inlet the same amount on each one. it is really hard to get them all in without lubrication. Wd40 or a little engine oil around the o ring will go a long way to helping.
Gus
  182Turbo,DCi90
Then fit the 2 bolts holding the fuel rail. this will sometimes help the injectors push in a little more if they arent in enough.
I wouldnt worry too much though, if the o rings are in the inlet then all will be well.
Gus
  182Turbo,DCi90
wiggle up and down whilst pushing with both hands , try starting from one side and working your way across.
Stay Puft
  Clio 172
Did you wipe it up and check fuel wasnt pissing out still.
Yes mate, it was literally pissing everywhere which it isnt doing now. All covers etc on and now im gonna have a massage.
No idea how mechanics do it, my back is killing!
Stay Puft
  Clio 172
it's not fully in. have you got a grown up who could help you:tonguewink:
I didnt know the orange bit needed to be in too!
Thanks again all. Was only meant to be an oil change, but £60 and 6 hours later, oil is changed and I have a new injector, yay.
Stay Puft
  Clio 172
Brilliant stuff.
I look forward to the thread about changing brake discs ending in you asking for help on how to get the gearbox back in. :tongueout:
On a serious note, well done for having a go yourself and sticking at it.
My rear brake pads are getting low.. what can go wrong!
