ABS Speed Sensor - Which Hub ?
AdamCup
Hey guys,
Does anyone know which hub the speed sensor for the speedo is located on ? I've seen from other posts its the N/S but they don't mention if its front or rear.
AdamCup
are you running it without abs?
I'm in the process of building a track car so, yes i will be running without ABS. I've removed the ABS pump, not realising that the ABS ECU is part of the ABS pump which is needed for the speedo so i need to reinstate the ABS pump to get my speedo working again.
  dan's cast offs.
weld some pick up points on the os inner cv/cup and run a sensor from there to the signal wire on the speedo.
  dan's cast offs.
pick up points in the o/s inner cv cup and sensor is going to be a lot easier than messing round with the abs pump/ecu etc.
