Coilovers for my 182
  megane 265/clio 182
Unsure what to go for on my track 182 ?? What are people using and reccomend and if anyone knows of any good deals
Yosemite Sam
  Whichever has fuel
Depends entirely on budget.
My friend has just had AST's fitted and set up by the man Curtis, and it's unbelievable.
But if you don't want to spend £2k+ then something like Bilsteins are a fair compromise but are a little soft if you're an out and out track man.
Avoid any of the crap like V-Maxx.
And whatever you decide to fit, make sure your bushes/strut tops are new or at least in very good condition. And don't forget to budget for a proper tracking/camber set up at a reputable place that works with track cars. I.e. Don't go to kwik fit and spend £25 on tracking.
  megane 265/clio 182
Maybe 600-700 it ocasionaly goes on road but mainly track. Maybe push a little more on budget. Will have to look for somewhere close or close ish to Swindon to set up once on.
Yosemite Sam
  Whichever has fuel
Have a look at Bilstein B14's.
I think BC make some for Clio's too and they have a good rep amongst other car clubs.
BC racing coilovers as you can adjust height and pre load, and you get the option of solid top mounts. Think they're around £700-800 last time I looked.
sburrell93
Scotland - South
Gaz Golds are another option around that price range. I've just went with a set of those for mine although I can't comment on how good they are yet as the car is still on axle stands lol
Niall
I've been questioning the same thing for mine on a similar budget. Stuck between Bilsteins and the Gaz Golds. Leaning towards Bilsteins for mine since mine mainly sees the road.
For you and mainly track work I'd probably go for either the BC's or Gaz Golds as above.
Jekyll
For track id be going with BC's. Plenty of adjustment, 30 way clicks from soft to hard and you can adjust the height without altering the bound/rebound as the adjustment is would into the strut itself, rather than a spring on a platform.
Another nice touch is the adjusters for the damping are all on the top so no wet knees. They are are also coated so no rusting.
Here's a few pics of my old ones to show the quality of the kit.
https://flic.kr/s/aHsjX9Ss7g
  megane 265/clio 182
Where's best to buy these mate? Is there different options on these to? Sorry new to this cheers
Jekyll
Those bc's look proper pornographic! Are they too hard ([emoji38]) for the road?
Not at all. I had them on fully soft as it was like being in a normal car with a sports suspension. Fully hard and they are hard! The good thing is, with the adjusters being on the top, you can just stop off and fiddle with them and play about till your happy. Obviously once the height and springs are where you want them.
I loved them and would definitely have them again. I prefer them to my bilsteins, but they are more expensive. However you get all that adjustability.
I'm not 100% sure. I got a good discount before as i bought another set of different coilovers from a company and they leaked in short time. They was cheapies, mind. The company took the old ones back and discounted me on a upgrade suspension kit, which was the BC's.
Maybe @MicKPM is the best person to speak too? Pretty sure you can change the spring rates too.
looking now thanks guys just unsure on what set to go for of the bcs
If funds allow go with the DR's with solid top mounts if solely a track car? I'll be going with DR's with 8kg/8kg spring rates when I get them as this is similar to the AST spring rates of 80n/mm = (8kg).
  megane 265/clio 182
thanks mate i believe the brs said something abiout rear adjustment on something will try see who will do a deal as wouldnt mind some for my r26 aswell
  megane 265/clio 182
Drs mate Kevin said as it purely track odd trip to a petrol station or mot then go for them took his advice
  megane 265/clio 182
Kevin self at kam racing mate. Yea will fit them then find somewhere as local to Swindon as I can to set up etc
  megane 265/clio 182
Will do mate can't wait now just need to look into the set up side
  megane 265/clio 182
Now have these thanks to Kevin self @ kamracing roll on getting fitted
Mr Trailer Man
Worth checking the big central nut to see if it's tight. Sometimes they come delivered a bit loose and that'll knacker the bearing.
Check once fitted to the car, so that there is some weight/load on the bearing.
