@SafetyDevicesDaniel
Any pics of the tab you cut out of the dash bar
Hi All,
Following on from post #120 / #136, I thought I'd follow on with more explanation on cutting the steering bar.
It turns out the steering column support bar in our development vehicle was cut before arriving with us, however I have included photos to show how we rejoined the structure on the second vehicle.
We suggest removing the section of steering column support bar using a cutting disc. It's then possible to install the cage for the final time (after test fit and welding/painting of plates) and replace the dashboard before finally inserting and welding the joining stub.
It is possible to weld around the outside of the stub end nearest the steering column, before welding the other end from the outside edge of the end plate as shown in the photos.
The joining stub will be included in all kits.
The steering column support bar in its original form (photo DSC07816)
The bar cut and removed (photo DSC07817)
The replacement stub in position (photo DSC07821)
The stub in position welded at both ends (photo DSC07822)
