Coilovers for my 182
  megane 265/clio 182
Ok mate thanks for that getting a mate at his garage to fit so will mention. Got to take of topmounts and put back on when fitting to
  megane 265/clio 182
I went for 9/8kg wondering if I can still run a rear strut brace with these?
  megane 265/clio 182
Strut brace wondred if would make any difference? Got pms rear arb on way and pms shifter to :)
Jekyll
I've found them to be fantastic on the road. I preferred them to the bilsteins.
Everything about them was great. Price, quality, adjustments, performance, etc. Obviously that's my personal opinion but for what they cost, I'd say they are the best out there in that price range.
  172 Turbo
Tempted to swap my B14s whilst I move the bits from cup to turbo. Will have to give it some consideration. Thanks :)
  megane 265/clio 182
Looking good, how are you finding the 9kg/8k spring rates on the road?
Drove twice was on hard on way home after fitting needed a gum shield lol. Set soft ATM and not to bad don't drive daily so that's a plus. Will find out sat how good it is doing the whole day at Combe rs owners club ;)
Drove twice was on hard on way home after fitting needed a gum shield lol. Set soft ATM and not to bad don't drive daily so that's a plus. Will find out sat how good it is doing the whole day at Combe rs owners club :wink:
@Niall
That's good to know, i'll be going 10kg/8kg but mine is only really driven to and from track.
Get some vids up of Combe
  megane 265/clio 182
@Niall
Just knowing what settings now for Combe and if to adjust topmounts or not. Also has eibach camber bolts on front. Will be taking to get corner weighted and set up properly once cage arrives and pms shifter on but will get some vids up. Did well last year and was running crap suspension etc
Maybe try and set the camber up by eye, I done mine by eye with camber bolts and got -2.3ns and -2.4os, lol. Regarding damping, full hard on the rear and middle setting on the front and adjust accordingly throughout the day, if wet middle setting on both and adjust accordingly.
  megane 265/clio 182
Lol ok mate will do by eye on that for now. Think ment to be dry sun little cloudy. Got my pms arb set on middle for now aswell. Running r888r tyres so any tips on tyre pressure?
Another DIY way to set the camber is with a spirit level, its more so to get it even both sides. I run R888's and as James mentioned above 30psi hot pressure all-round is a nice starting point. I set mine cold around 25psi front/27psi rear and after a few laps depending on weather find the fronts need dropping around 2-5psi and the rears 1-3 psi. Again you can play about with pressures for small changes in the way the car handles, see below.
http://www.trackdayguru.com/tyre-management.html
  megane 265/clio 182
Nice one buddy thanks let you know how I get on :)
  Clio 172 (CUP)
Glad I came across this thread, ready to pull the trigger on buying some of these for a 172 cup, interested in the performance on track with those spring rates on the DRs.
Does anyone know if these are compatible with the PMS front strut and solid mounts? I'm I right to assume the mounts that can be purchased with the BCs offer additional castor (as the PMS ones don't)?
Don't think they offer caster mate no, but makes sense to get the BC topmounts with the coilovers as theyre only £60 extra...
https://www.kamracing.co.uk/car-tun...ilovers-172-182-renaultsport-inc-172-cup.html
