Which boot is leaking?Is there a difference in driveshafts if I have a 182 cup suspension? Can I use a 172 driveshaft? Boot where bearning is leaking
Sent from my SM-G930F using Tapatalk
Ive been told that it's part of the driveshaft? It's the inner boot that stays still while shaft rotates.Which boot is leaking?
You should be able to replace the boot without the need to change the shaft.
Ohhh. Ok, any special tools needed? Except your normal garage equipment?yup, you can replace it. off top of my head about £20 for gkn boot kit.
I'm not too bothered about knocking tripod off and on, I'm pretty well mechanically minded, only thing I'm wondering about is if it starts leaking again. £150 for a driveshaft will be reasonable if it does last and won't give me anymore hassle.Not true.
https://partsouq.com/en/catalog/gen...DC0p7EkpWQHMF$&vid=1247&cid=75604&uid=3233&q=
You may find a GKN boot on eBay at a better price, but to save the hassle of knocking the tripod off & back on, just get a £50 J&R shaft complete or a Shaftec R396L for somewhat more, but I can say Shaftec do last, 25k miles on mine to date.
And top up/change the gearbox oil when your done.
How much is j&r drive shaft? What about getting one from euro or any other car part place? Surely there isn't a different shaft size option :/@LeeRS had a similar issue. He’s just bought a complete driveshaft from j&r because he’s minted and money is no object.
£50, 182 cup has15mm wide abs rings, link works fine.How much is j&r drive shaft? What about getting one from euro or any other car part place? Surely there isn't a different shaft size option :/
I'll ring my local part supplier tomorrow and see if he can get hold of one. Yes link does work fine, I think Tapatalk had a hicup.£50, 182 cup has15mm wide abs rings, link works fine.
J&R only sell direct from eBay, Andrew Page will supply Shaftec products.I'll ring my local part supplier tomorrow and see if he can get hold of one. Yes link does work fine, I think Tapatalk had a hicup.
Which ever side you think has gone, full lock to that side and drive your car. It should make a clicking sound.Just out of interest what's the best way to check if the cv is dead?
No clicking sound but hard to tell over the exhaust. Any other ways with the car jacked up? Should there be movement?Which ever side you think has gone, full lock to that side and drive your car. It should make a clicking sound.
Yea after a bit more digging I found their website too. Thanks for you help, I owe you guys a cuppa if we ever get a chance to meet hahaJ&R only sell direct from eBay, Andrew Page will supply Shaftec products.
That doesn't tell me the cv is fucked just the boot isGrease everywhere too
You can do it with car jacked up and full lock just by turning wheel. Also lift your driveshaft up and down to see if you got any excessive movement, in and out and also rotate it.No clicking sound but hard to tell over the exhaust. Any other ways with the car jacked up? Should there be movement?
If I could send a cuppa over paypal I would. Actually might just mail a teabag for you hahaWe
We accept paypal
Let's get off the topic of teabagging guys
Would you like a tea bag too?Let's get off the topic of teabagging guys
Only if it's YorkshireWould you like a tea bag too?
Decided that for £50 I'll save my self some faffing about and replace full shaft.circlip to get the tripod off and that's about it.
Oh you bet my friend. Straight from Leeds.Only if it's Yorkshire
Only local! Drop the teabag off yourselfOh you bet my friend. Straight from Leeds.
Clio friend? Clio friend!! [emoji4] mines not lowered so I'm good ha.Only local! Drop the teabag off yourself. Any pics of your clio?
I think you're probably best for the price of a j&r shaft. Apparently they don't recommend for lowered cars but they do provide warranty. Just don't let them know it's lowered if the boot splits again. Apparently you can shave some off the block near the boot to stop it being so close and catching?
