The following day I set about finding out why the gearbox wasn’t happy. I discovered that with the engine running I couldn’t select gears, however with the engine off I could get all gears no problem. Also when starting in gear with the clutch depressed it felt like the clutch was dragging.
So out came the box, after just having the alignment done I lifted it out the top so as not to disturb the subframe:
With the clutch off I discovered that this was the cause of the problems. Relieved I decided that the box would be okay and just a new clutch would be required:
Upon removal I discovered this mount was broken:
I didn’t like it anyway, so managed to pick up a second hand PMS one:
New clutch ready to go:
Now... This is the point where I need to admit that I have a problem. I just can’t leave things alone. It would have been easy enough to refit the box and do a few more track days before the year was out. But no. Not me.
So I picked up a few more bits that were unnecessary at this point.
OZ Superleggera’s because they were cheap and why not?
New Milwaukee impact guns because they were a good deal, so again, why not?
Then I decided that the next sensible step was to remove the engine, this would give me the chance to clean and tidy the bay. Also fitting the engine and box together would be easier than trying to wrestle the gearbox back into the bay.
More wiring to be removed and tidied:
Engine and box - this trolley has had a few different engines over the years!
The engine bay was filthy. But it was December and it was genuinely -6° outside. I couldn’t wheel the car outside and hit it with the pressure washer could I? Yes - Yes I could. I wouldn’t recommend it, but it was kinda holding up progress so needed done. No pictures of this stage because it was pretty horrible. The water was freezing instantly and the driveway became an ice rink and the pressure washer broke. However. Mission accomplished. Here’s a before picture:
I pulled the car back inside, shut the door and fired up the space heater so that me and the car could defrost a bit. I then dried the bay off, removed the ABS pump and all lines plus a few unnecessary brackets and painted a few bits to tidy things up.
After:
