Will the engine run better after changing the dephaser pulley and belts
Clio182mike
Car  Clio 182
Hi, firstly I have searched. Will having the dephaser and belts done make my Clio even better than it already is? It's good now but can I expect more?
Only if they're currently timed wrong. They're a maintenance item, not a performance upgrade
“After changing the belts and dephaser”
Yea but that bits already been established, so i thought I'd mention something else.
Mind you plugs, leads, coilpack, etc etc are all worth a mention too.
On a relatively stock car the idle and general shouldn't be particularly rough.
:smile:
So esentiallly, yes the engine will run better, like new infact if you replace everything.
