Yep, works really well and kicks out quite a lot of heat. Will help bring engine temps down as said too.I have a little heater from Tweeks, as does @dann2707, that plus antifog works fine.
Mine. Not finished yet but you get the idea.....
Yes or the original control panel.The little heaters are neat. Adam cup what will you have a switch to run a fan to blow some air on the screen?
Yep :up:Did you do this with the FF heater box?
Yep :up:
I chopped off the front bit and locked the vent flap (inside) in the screen demists position. I will be gluing and sealing a piece of acrylic to fill the gaping hole.Any tips on how you achieved it? Looks exactly what im after! Assuming you just cut the bit off you see in the pic and blank it and then run a simple on/off switch?
Using the original blower just with the AC insides removed.Ah I see, thanks. What are you doing about power?
Poverty spec heater is lighter still and £20 on eBayUsing the original blower just with the AC insides removed.
Sent from my SM-G955F using Tapatalk
Any idea how much lighter ? Can't be much?Poverty spec heater is lighter still and £20 on eBay
Heater fwends
Sorry to dig up an old thread but I’d rather do this than open a new one...
Does anyone have a parts list of what’s needed to convert to a race heater?
I’m looking at doing this ASAP and would like a bit more info please
Anyone got any info on wiring the standard heater to an on off switch just for screen clearing
I cahnged the blower motor/heater box to a cup one (non ac) and then lengthened the main 12v feed, included a switch on the dash and done. Set the heater box to blow straight onto the screen and the wiring runs the blower/fan at max only.
It's a little crude but very effective
That's exactly how mine is set up. Never had any issues with it working
eBay
eBay
"12mm Equal Hosetail Elbow in Brass for Fuel Air Water Etc Buy 3 get 1 Free"
From this seller:
https://www.ebay.co.uk/sch/context-pneumatic-supplies-cpm/m.html?_nkw=&_armrs=1&_ipg=&_from=
Sorry for needing babysitting here, but been trying to get this to work from a switch for a while now. Which wires is it im splicing into to add a switch?
View attachment 1372872@Ads29
