182 Top mount failing questions
Flob
Hi Guys,
New to 182/Clio ownership and all was well until the weekend!
Jacked car up to jetwash underneath to get a good idea on what would be needed for up and coming MOT. All looked ok bar a few parts (new posts to follow), lowered car back down and drove home, car began to knock while pulling away and braking from front right - could feel through the steering also. Figured it must be an engine mount until I looked at the top of the struts (see image below), I can only assume that this is NOT normal, what has failed to let this happen?
Any advice would be great - about to purchase a pair of new Renault top mounts, is there anything else I should get? Also considering new dampers (think mine has the cup pack) and a spring kit.
Cheers and hello!
Rob,
Drivers side:
Passenger side (looks much better but still not totally what I would expect):
  PH2 172
Hi Guys,
Cheers and hello!
Rob,
Drivers side:
Looks normal.
Drive forward 10 yards with the steering straight and they sit square.
There should be a gap between the turret and top cap.
If you do replace them, get the Febi ones, not the modified Renault items, to avoid this palava.
https://www.cliosport.net/threads/172-new-top-mount-modified-spacer-issues.641094/
Flob
Just reading through the post link you sent now, thanks very much.
I am amazed that this is normal!
This is very bad news for me too as the clunk is really bad. Wondering what the hell it is now - thought I had it cracked.
Pulling away, clunk, braking, clunk. Pot holes and bumps no clunk....
  PH2 172
PS - what is actually stopping the top of the strut from moving about if the top mount/cup (pictured) is aloud to move about so freely?
The bearing is located in the rubber seat under the turret.
https://www.ebay.co.uk/p/Febi-Bilst...5&clk_rvr_id=1553779620232&afsrc=1&rmvSB=true
Clunk when braking or pulling away could be wishbone bushes, ARB bushes, bottom ball joints, a loose caliper, worn engine mounts.
Get an MOT station to take a look.
Flob
Thanks for your help!
You don't happen to know if that kit comes with the bearing do you? Their description does not mention it.
Think I'll probably take a day off this week to strip down suspension, tbh its all probably tired enough to to warrant replacement.
Rob,
  PH2 172
Rob,
There are 3 items in the kit, 2 are obviously not the bearing, the round object is.
Make sure to fit it the right way up!
Flob
Cheers, my ARB bushes don't look fantastic, I intend to replace these at the same time. Access looks a bit.... fun :)
Todays buy list includes lower arms, ARB bushes, Shocks, Top mounts - any other suggestions for front suspension refresh would be welcomed, I am very new to these cars so have no idea what the common problem areas or recommended replacements are.
Flob
Knock/clunk fixed. I am nearly too embarrassed to give the explanation but to assist other, future idiots like me I will confess.
I had not torqued up one front wheel, bolts were ratchet tight so not falling out but.....
It was a REALLY hot day, and i was convinced I had torqued everything - should really go with the RAF's motto of never installing a bolt unless you torque it.
Naturally I am confessing to you lot, who will probably never meet me in person in order to issue an appropriate level of pisstaking, however to my friends and family - the engine mount was loose.
