Workshop lighting
Hi guys.
I’m looking for a good workshop light that I can use everywhere. Something bright, and gives a good amount of light.
Uses... under the car, engine bay, interior etc.
Perks... maybe magnetic, battery pack rechargeable etc.
What do you recommend?
What do you use?
I have LED strip lights on the roof and the walls to fill the room with light. You can then get more portable units to go on the floor or hang in the engine
I have a Milwaukee work light which runs off the same batteries as my impact guns and drills.
It's not magnetic but it does have hooks to attach it to most things.
Might be worth looking at something like that if you have similar cordless tools?
Has anyone got one of these, or similar for working under their car?
https://www.screwfix.com/p/diall-portable-led-work-light-24w-220-240v/1098k
I’ll be putting new lighting into the unit later in the year, but I do need a handheld/magnetic led unit for the inspection stuff.
I would highly recommend these for unit lighting
https://www.ledhut.co.uk/spot-light...g-light-ip54-rating-dust-and-splashproof.html
just put 3 in my new workshop and they are ace, 2500 lums each. I got mine when led hut had a sale at 50% off, so £20 each, which is an amazing price for what you get. also dimmable
they also do a 45w version which is 3600 lums
no warm up time like tubes and no cold start issues like tubes
I be one very similar to that at work. It's very bright and gives a hood spread of light too. I can't tell you what rating it is though because the sticker has worn off. Shoukd be fine fit under the car.
I’ll be purchasing 6 or so LED lighting strips for the ceiling as I’ve got quite a large space and id need 12 of those above
Yeah I have that exact one. It's bright as f**k!
I shall purchase one of these for the work under the car then ??
Thanks gents
Yes I have 2 of them mounted to the roof of my garage. There really good for the money!!
I also have some rechargeable Elwis lights which have a few different mounting options like a bonnet bar (which is again mounted to the roof) small stand, 6 feet stand and really strong magnet
After reading a few of the reviews on this £10 rechargeable Unit, I put an offer in...
Yes it’s a cheap item and probably coming from China, but as an inspection light, I’m hoping it’ll get into the tight places.
I’ll be buying an LED light from screwfix later and then I’ll be looking to purchase the LED tubular ceiling lights a little later in the year
I have three of these and can't tell if it's day or night when working in the garage https://www.ryness.co.uk/deltech-60...MIlrvX1vPi2wIVjrftCh3BQgBmEAQYASABEgIs7_D_BwE
Having daylight colour is a huge difference over 4300k lights.
edit:
slightly misread your question. I use this and a 6000k 100w LED bulb for under the car.
https://www.toolstation.com/shop/Lighting/d220/Site+Lights/sd2480/Work+Light+5m/p81886
Those strip lights you’ve got, does the wiring enter the fitting at the ends or through the back like a typical strip light. Some of the LED lights I’ve seen have the cable coming out the end, I want concealed wiring. Cheers
Oh and are yours the daylight ones or cool white.
Let me get you some pics later :) I’ve got the daylight ones.
I’ve just fitted these LED lights from screwfix.
Really pleased with them. Currently on 13a plugs using an extension lead from the house lol, as I’m in the middle of getting electric to the garage
@Short Legs sorry for taking ages to do this. They are the daylight ones so 6000k, totally worth it over the bluer colours a lot of lights seem to be. I can work on the car day or night and there's no difference. Serious bits of kit. Connection has a length of wire which I ran into those junction boxes. Tried to take a photo but the exposure was a tad difficult.
